Problem with spline objects in Boris fx
COW Forums : Boris FX
Dirk Billand
on Mar 21, 2010 at 1:45:36 pm
I'm trying to animate the stroke of a spline object. Everything works as expected in the plugin's preview and in the preview of Premiere Pro. But after rendering the spline object flickers. In most frames the spline object is not visible. When I delete the rendered preview files, everything is ok again. But I would prefer to get the correct display in the rendered files, not just in the preview. What can I do?
My system configuration is: Intel Core i7 860 with 4GB RAM and Windows 7 64Bit Edition, Adobe Premiere Pro CS4 with all updates applied and Boris fx 9.3.2.
Matthew Mullen
Re: Problem with spline objects in Boris fx
on Mar 22, 2010 at 2:45:01 pm
Could you send me the project file and maybe the rendered output you are seeing.
My e-mail is mattm@borisfx.com
Anything over 5MB you can send to me using yousendit.com
I can take a look at it for you.
-Matt
