Removing BCCAE5 from AECS3
COW Forums : Boris FX
Michael Dorian
on Mar 15, 2010 at 4:42:32 am
I am having no luck in removing the Continuim Complete plug-in from After effects CS3. On am Intem Mac pro and running 10.5.8 Fisrt off, i cannot even find the plug-ins from Boris.
Any help on this would be greatly appreciated.
Michael Dorian
Ben Heusner Brownlee
Re: Removing BCCAE5 from AECS3
on Mar 15, 2010 at 7:09:23 am
If you do a Spotlight search for "BCC" that should lead you in the right direction. There are several folders to look at. Here are a couple:
Mac HD > Library > Application Support > Adobe > Common > Plugins > CS3 > Mediacore > BCC
Mac HD > Library > Application Support > BorisFX > BCC
These are from memory, so you'll have to forgive me if the titles are not 100% exact. They should get you in the right direction. The BCC search thing is the key I think.
Hope that helps,
Ben
Curious Turtle Pro Video
Training | Editing | Support
Out Now - Creative Color Grading with Apple Color, Film Wash Color Effects Vol. 3
& Mocha training for AE & FCP
Matthew Mullen
on Mar 15, 2010 at 3:07:10 pm
Ben put you in the right direction.
The plug-ins can install into 1 of 2 directories on the Mac. They are most likely in the Media Core folder but here are both. Locate the BCC 5 folder and simply remove it:
Mac HD>Library>Application Support>Adobe>Common>Plug-ins>>MediaCore
or
Mac HD>Applications>Adobe After Effects CS(3/4)>Plug-Ins
