FEC Transition Filters in FCP
COW Forums : Boris FX
Kuhnen Brown
on Mar 9, 2010 at 12:54:48 am
Hi.
FCP 7.0.1
FEC FxPlug 5.0.2
OSX 10.6.2
Boris RED 4.3
Grafitti 5
When applying transitions using any filter from my FEC transition filter set in FCP, I get this error: "The effect FEC 'name' failed to render." I am applying the filter the same as any other filter in FCP between the two clips on V1, in RT Safe mode.
This only occurs with FEC transitions (Boris BCC and other Apple transitions all work). Now the regular FEC filter effects work fine. It is only the transitions that are not working. FEC filters are also working well in Boris RED. Anybody got a clue?
Thanks, Kuhnen
Matthew Mullen
Re: FEC Transition Filters in FCP
on Mar 9, 2010 at 1:06:17 am
This was fixed in the 5.0.3 patch update.
You can find it at this link:
http://borisfx.com/login/reg_form.php?action=FEC502
Kuhnen Brown
on Mar 9, 2010 at 4:31:45 am
Thanks Matthew,
The update did the trick!
Kuhnen
Kuhnen Brown
InterMountain Digital
Oregon
Matthew Mullen
on Mar 9, 2010 at 2:25:02 pm
Glad to hear!
