Realistic brush in Red 4.3
COW Forums : Boris FX
Mark Rothman
on Mar 8, 2010 at 8:29:37 pm
Can anyone recommend a way to make the paint effect in Red look like you're using a real paintbrush with rough edges?
Any suggestions are appreciated.
Matthew Mullen
Re: Realistic brush in Red 4.3
on Mar 8, 2010 at 8:38:12 pm
Mark,
Try playing around with the "Dab" controls.
Set Dab scatter to about 2 and Spacing to 0-1. Play around with the shift and angle as well...this will help achieve a less smooth look with the brush.
Mark Rothman
on Mar 8, 2010 at 9:38:23 pm
Thanks Matthew, but I meant like painting on an image with a wide paintbrush ... with bristles. Maybe use some kind of streaky background mixed somehow with the original image so the edge is streaky as the paint edge moves along?
Does that make sense?
Matthew Mullen
on Mar 8, 2010 at 10:11:06 pm
Does the pic below look anything close to what you want to achieve?
Mark Rothman
on Mar 8, 2010 at 10:50:20 pm
Sure. Did you paint that on the background?
Matthew Mullen
on Mar 8, 2010 at 11:51:43 pm
Shoot me an e-mail to mattm@borisfx.com and I can send you a project file so you can take a look at what I did.
peter mcauley
on Mar 9, 2010 at 6:00:45 pm
If you open the style palette, and go to the brush tab, then click on the pop-up above the brush profile icon and you should see a variety of different brush sets that can effectively emulate many different looks, including a bristle brush. For the bristle brush, select "spray brushes" and then scroll the panel on the right to the bottom and you should find a few to your liking.
You can add to the built-in brushes using image files to generate your own customized looks.
I hope this helps,
Peter.
