Boris FX in Premiere 6.5
COW Forums : Boris FX
Mike Robinson
on Feb 9, 2010 at 10:56:39 pm
Are premiere 6.5 and Boris FX 8 compatible? Also,it seems that there is compatibility issue with my video card(NVIDIA GeForce 8400 GS).
The ERROR MESSAGE:
A component of your system has been detected which is not officially supported by Boris FX for OpenGL accelerator previews. The Boris FX state will default to off, but may be re-enabled from the Preference
or Preview Menu. This has impact on the quality or performance of an effect's final render.
Status:Your system's video card driver version is not supported by
Boris FX.
END MESSAGE
The startup screen flashes on and then then close FX 8. Does anyone know what is wrong?
Mike R.
Jon Kozenko
Re: Boris FX in Premiere 6.5
on Feb 10, 2010 at 10:52:37 pm
FX 8, I believe, should be able to install into and work with Premiere 6.5, but note that FX 8 is the last version that would work with that version of Premiere. As for the error, this shouldn't prevent the software from launching. Is FX 8 able to launch as a stand-alone program? If it is, shoot me an email at support, as you will likely need a file to dis-engage the OpenGL in FX8, and I cannot give that to you here.
