Boris Effect too large for Vegas
COW Forums : Boris FX
Glass Onion
on Feb 7, 2010 at 1:52:56 am
Hi, has anyone had the problem with Boris and Vegas 8 where Boris states the effect is too large for Vegas to handle and that the standalone Boris app should be used? Is there anyway around this?
I'm using winxp32 with vegas 8 and boris 4.
Matthew Mullen
Re: Boris Effect too large for Vegas
on Feb 8, 2010 at 3:57:07 pm
What is the exact message you are getting?
Glass Onion
on Feb 8, 2010 at 7:47:01 pm
That is the exact message. What I was hoping for is a vegas setting or boris setting so this message can be ignored. Like increasing the ram in vegas or something.
The effects is a write on effect with 17 paint strokes as a mask revealing the text.
It seems vegas can only handle 3 strokes before this message pops up.
I've tries two different machines and the limit is 3 paint strokes in vegas.
Is there any work around so I can render this effect in vegas without having to use the standalone boris app?
Matthew Mullen
on Feb 8, 2010 at 8:12:25 pm
Does it come up when you apply the filter or when you try to launch the Boris interface?
It says "the effect is too large for Vegas"?
What are the full specs of the machine?
Glass Onion
on Feb 10, 2010 at 11:36:58 pm
It comes up when I apply the effect.
It's not machine specific so the specs are not needed. It's vegas specific.
Matthew Mullen
on Feb 11, 2010 at 12:34:44 am
Glass,
I've never seen this error before so I'm just trying to gather as much information as possible so I can help you resolve the issue.
how long is the clip you are applying Boris too? Does it happen on all clips? Can you post a screen shot of the error?
-Matt
Glass Onion
on Feb 13, 2010 at 8:36:09 pm
Thanks for the help.
I've given all that info already in the previous posts.
Do you own Vegas? If you do, apply boris red and paint 10 separate strokes from the top to the bottom of the video (like a prison cage). Apply the filter and the error pops up.
The Boris manual talks about this vegas limitation which means it is well known and documented by Boris.
I was wondering if anyone had found a work around at all besides rendering in the standalone Boris app.
Matthew Mullen
on Feb 22, 2010 at 5:02:23 pm
Sorry for the delay, I was on vacation.
I was able to confirm that this is indeed a limitation in Vegas.
Glass Onion
on Feb 22, 2010 at 6:27:42 pm
Yeah, what I wonder is there a hidden Vegas setting to get past this limitation. Since 64 bit computers can address more ram, it makes sense that there might be a setting somewhere to stop this old limitation.
