Boris Stabilizer Jello Effect
COW Forums : Boris FX
Jeff Scholl
on Dec 8, 2009 at 4:48:43 pm
Hello,
Is there any settings I'm overlooking to reduce/eliminate the jello effect seen in this clip?
http://www.gravityshots.com/BorisJello/
(warping distortion in the trees)
This was from an HPX170 (global shutter)
Thank You,
Jeff Scholl
Matthew Mullen
Re: Boris Stabilizer Jello Effect
on Dec 8, 2009 at 5:31:26 pm
Hey Jeff,
What host are you using this with?
Have you tried increasing the "Span" parameter or decreasing the velocity limit.
If those do not yield better results let me know. We can arrange for you to send us your clip and we can test with it.
-Matt
Jeff Scholl
on Dec 8, 2009 at 6:53:36 pm
Hello Matt,
I did play around with the flow options but never did get rid of the distortion.
I was just thinking if the HPX170's OIS would produce a bit of distortion in the raw footage.
Best,
Jeff Scholl
Matthew Mullen
on Dec 8, 2009 at 7:18:03 pm
I'm not sure without looking at it myself.
Do you have a yousendit.com account? If you do or want to open one post the original and let me know which host software you're using and I'll take a closer look.
-Matt
Jeff Scholl
on Dec 8, 2009 at 7:45:34 pm
I'm using CS4 (XP)
Here is the tree sample:
http://www.gravityshots.com/TreeShake.zip
Thanks Matt!
Matthew Mullen
on Dec 8, 2009 at 8:51:22 pm
Sorry,
Can you shoot me the AE project with the settings you are using as well for the stabilization?
mattm@borisfx.com
- Matt
