Flicker and Shake on BCC-avx or RED?
COW Forums : Boris FX
mike meyerson
on Nov 27, 2009 at 8:50:31 pm
I noticed the free flicker and shake effect for BCC-fxplug...what's the easiest way to get an effect like that with either BCC-avx or Boris Red?
thanks
peter mcauley
Re: Flicker and Shake on BCC-avx or RED?
on Nov 30, 2009 at 5:56:15 pm
Currently this filter is FxPlug exclusive and cannot be used in any host other than FCP or Motion. It might migrate into other products in our line but for now the requirements to use the fiter are that you install it into Final Cut Studio host.
If you just need some flickering and shaking of the video clip, then you might want to check out the BCC Film Damage filter (you can disable all of the features in this filter except for Flicker and Shake) or the BCC Jitter filter. These filters are accessible in other hosts, such as RED of BCC AVX.
Cheers,
Peter.
mike meyerson
on Dec 1, 2009 at 3:49:05 am
thanks peter...will give that a try.
