Boris RED exporrt
COW Forums : Boris FX
Steven Humphrey
Boris RED exporrt
on Nov 3, 2009 at 4:53:02 am
I have successfully created a spinning 3D logo in Boris RED but, when I export it as a movie the aspect ratio changes...i can't seem to figure out why...
Matthew Mullen
Re: Boris RED exporrt
on Nov 3, 2009 at 2:23:49 pm
Steven,
When you export a movie you should see a compression settings box in the lower left of the Movie Export Settings Screen. The box has a button for "Compression Settings" shows your compression type and the Frame Size. You want to make sure the frame size matches your project. If it is not navigate to Edit> Preferences then go to the Export Tab...For each export setting make sure "Use Project Frame Rate" is checked.
This should solve your issue, if not let me know and post the export settings you are using.
-Matt
