Pan and zoom file types?
COW Forums : Boris FX
Jef Huey
on Oct 4, 2009 at 3:04:36 am
Just started experimenting with BCC 6 - Pan and Zoom that comes with Avid MC4.
What are the supported file types? I can not get .tif or .jpegs or many other common file types to load. Am I missing something in the UI?
thanks,
Jef
Matthew Mullen
Re: Pan and zoom file types?
on Oct 5, 2009 at 2:21:00 pm
Jef,
Have you seen the PDF file for this filer. I included it below. It lists the work flow for Automatic, Semi-automatic, and Manual work flows.
http://www.borisfx.com/Documentation/BCC6AE/BCC%20Pan%20And%20Zoom.pdf
It seems like you might be missing a step somewhere.
If you can't figure it our from the PDF let us know your workflow and what you are trying to do.
Jef Huey
on Oct 18, 2009 at 6:10:56 pm
I read the pdf you offered. It does not address my question.
My question is: what file types does Pan And Zoom support? I can only get PSD files to load. Can other file types such as .tif, .jpeg, or .png be used? If so how?
Jef
Matthew Mullen
on Oct 20, 2009 at 2:51:00 pm
Jef,
I am able to select these files types.
What OS are you running on?
Does it throw an error message? Or just not show you the other files?
Can you post a screen shot of what you see? You may be looking for PSD files only.
