Looking for Plug in similar to FC Matrix Trans
COW Forums : Boris FX
Darwin Phillips
on Aug 9, 2009 at 4:47:37 pm
I'm looking for a transition similar to the FCP "Matrix Trans" which takes your video frame and multiplies it, zooms out and back in on another frame. Don't think it's a boris FX but I could be wrong?
peter mcauley
Re: Looking for Plug in similar to FC Matrix Trans
on Aug 10, 2009 at 1:04:19 pm
Hi Darwin,
If I understand correctly what you are trying to do, you should be able to achieve that with Boris RED or Boris FX. And for that matter, you should be able to do it with BCC also, using the BCC Composite filter.
I hope this helps.
Peter.
