shifting keyframe values
COW Forums : Boris FX
Peter Burn
on Jul 25, 2009 at 7:43:53 am
Is there a setting to prevent changes to key frame #5 affecting #4 and #6? I change the xyz and position after placing the title and holding for 4 seconds then it should go away but the disappearing, spinning and tumbling commences at frame #4?
Peter Burn
peter mcauley
Re: shifting keyframe values
on Jul 27, 2009 at 1:06:51 pm
Hi Peter,
It's not exactly clear to me what you are trying to accomplish - if you would like to send me a setting and explain the effect that you are trying to create then I'll take a look at it and send a modified project back to you. You can send that to me at peterm@borisfx.com.
Cheers,
Peter.
