BCC6 3d extruded text - critical error
COW Forums : Boris FX
Daryl Brown
on Jun 29, 2009 at 6:51:28 am
i took screen shots of the error i get when i try to use 3d extruded text. I guess its because of my laptop graphics card. I don't know anything about the drivers i have for it. Anyone know how to fix this?
the error
graphics card test results
In heaven everything is fine
Boris Yamnitsky
Re: BCC6 3d extruded text - critical error
on Jun 29, 2009 at 1:11:31 pm
No, this may be an indication of some sort of installation mishap. Our installers place "shader" files on your system and it seems that the shader #19 for some reason can not be found by the plugin. It could be a registry problem or a problem of some files or directories moved around. Can you try to uninstall and re-install BCC? If that does not work contact our tech support
888-77-BORIS
Boris Yamnitsky
BorisFX
Daryl Brown
on Jun 30, 2009 at 9:34:06 pm
ok thanks, i guess ill re-install.
