seeing host video
COW Forums : Boris FX
John Roberts
seeing host video
on Jun 17, 2009 at 2:33:43 pm
Is there a way to see the host video while in Red. I am using FCP, I could do this when i was using M100, but am not sure how to do it or if FCP will do it at all.
Matthew Mullen
Re: seeing host video
on Jun 17, 2009 at 4:27:31 pm
This should work fine.
What are the symptoms, are you getting green video?
First thing you want to check is that your RT setting in Fianl Cut is set to Safe.
Also make sure you are applying the video filter to video and not a slug.
If you are still having issues after that please send a copy of your project along with your contact info and a description of the problem to Attn: Matt
peter mcauley
on Jun 17, 2009 at 5:04:28 pm
Hi John,
In addition to the advice that Matt offered, you will need to make sure that you have the following option set correctly for image previews:
Launch RED and select Preview>Image>Update Source
© 2018 All Rights Reserved
