Many entries in RED Keyframe Library have errors
COW Forums : Boris FX
Peter Honig
on Jun 11, 2009 at 1:31:13 pm
After updating yesterday to Red 4.3.3 I happened to take a very close look at the entries in the Keyframe Library (I had built the project previews in November 2006 when I originally bought Red 4.0). I am now surprised to see how many projects do not work correctly. The most problematic ones are those that use the obsolete filters: "2D Particles Advanced" and "Luma Pixel Noise". I don't recall at what point these two filters disappeared, but I definitely do not have them.
The most problematic areas of the Keyframe Library are "Filters->Noise", and "Filters->Particles". However, there are a quite a few entries in other areas that also do not work correctly. Though I build most of my composites from scratch, occasionally I use an entry from the keyframe library as a starting point. My question to BorisFX is are there any plans to repair the entries and eliminate the references to obsolete filters?
Peter
peter mcauley
Re: Many entries in RED Keyframe Library have errors
on Jun 11, 2009 at 1:58:28 pm
Hi Peter,
Thanks for bringing this to my attention - I'll move this forward to engineering to see what they can do to resolve the issue of the broken templates.
Cheers,
Peter.
Peter Honig
on Jun 12, 2009 at 3:57:25 pm
Hi Peter,
I have already repaired quite a few templates, including those that still worked but refered to obsolete versions of existing filters. My goal has been to elimate all references to "(Obs.)" filters. I would be very happy to share these with you if you wish.
Regards,
Peter
peter mcauley
on Jun 12, 2009 at 7:43:50 pm
Hi Peter,
Could you please send me an email off list? You can reach me at peterm@borisfx.com.
Cheers,
Peter.
