boris graffiti 5.3 question about charts and % sign
COW Forums : Boris FX
emmanuel duchemin
on Jun 6, 2009 at 9:44:50 pm
Hello guys
I try to make a simple chart in FCP, using Boris graffiti 5.3.
Everything looks nice, but I have a issue concerning the values.
I use a pie chart, with percentages. In the value tab, I check values to have the values displayed
SO the numbers are displayed, but NOT the % sign.
And I need this %...
peter mcauley
Re: boris graffiti 5.3 question about charts and % sign
on Jun 8, 2009 at 1:36:54 pm
Hi Emmaneul,
You can display the percent sign in Graffiti for pie style charts. Here's how:
• create a Chart Container track with the values that you want to show
• select the Chart Container so that it's parameters are visible in the Controls Window
• in the Values Tab, set the following:
- set the "enable values" checkbox to the on or checked position
- value type pop-up should be set to percentage
- precision slider should be set to 0
• In the Chart Tab, set the following:
- set the use pop-up to Value and Percentage
Hope this helps.
Cheers,
Peter.
emmanuel duchemin
on Jun 8, 2009 at 1:48:02 pm
Thank you for your fast reply.
But when I follow what you said I have a "/" sign after the % sign :(
peter mcauley
on Jun 8, 2009 at 3:34:32 pm
If you can please send me an email I'll send you a Graffiti settings file that has this set up correctly. I followed the instructions that I posted in my last response and was able generate a pie chart with visible percent values so there must be something else that is preventing the numbers from being displayed on your system.
My email address is peterm@borisfx.com.
Cheers,
Peter.
