Boris BLUE crash when opening setting with PSD converted to container
COW Forums : Boris FX
Dave DiPinto
on Apr 2, 2009 at 2:54:46 pm
Hey there Boris Crew,
I crash when trying to open most of my saved BLUE setting files. I figured out the culprit though, PhotoShop PSD files converted to containers.
Steps:
1. launch Blue
2. import a PSD file
3. select the PSD shape track and then Convert to Container from the Track menu
4. save the setting and exit BLUE
5. launch Blue and attempt to open the setting... BOOM.
I hope this is a known issue and there may be an update soon for this.
Keep up the good work there.
- Dave
peter mcauley
Re: Boris BLUE crash when opening setting with PSD converted to container
on Apr 2, 2009 at 7:09:27 pm
Hi Dave,
Thanks for reporting this - it is new and not something that we were aware of before your posting.
So ... I wonder if reproducing this issue is dependent on saving the PSD file from a particular version of Photoshop. I just tried it with PS CS1 and it worked just as expected. I'll increment the version with which I save out the PSD file to see if I can reproduce the problem. Meanwhile, perhaps you could send me a simple (and small) version of the file that is causing the crash on your system along with your system specs. You can send that to me at peterm@borisfx.com.
Cheers,
Peter.
