BCC Page Turn TR
COW Forums : Boris FX
Brian Holson
BCC Page Turn TR
on Mar 1, 2009 at 4:02:35 pm
I am trying to create a page turn over a title page created by Avid Title tool. When the page turns I'm seeing only black and not the page underneath. In the General Controls there is no option for "1st or 2nd below". Is there somthing I'm not doing? Any tips would be appreciated. Thanks!
peter mcauley
Re: BCC Page Turn TR
on Mar 2, 2009 at 1:48:52 pm
In the BCC Page Turn effects control panel, you should see a "Title-Matte" group. In the title group of controls, you should see the option to "Apply to Title-Matte". You need to enable this function to see through the alpha channel in the title.
We have a tutorial for this on-line and available to download here:
http://borisfx.com/download_files/BCCAVX3_Tutorial.pdf
Cheers,
Peter.
Brian Holson
on Mar 2, 2009 at 1:56:28 pm
Hi Peter,
Thanks for the tip. I did read that tutorial previously and the "title matte group is not available for some reason.
The challenge is that when I put the effect on V2 (the video page I want to turn) using the default settings, I can't see the background (avid title) that is on V1.
peter mcauley
on Mar 2, 2009 at 2:00:20 pm
Hi Brian,
It might be that the title matte feature is not included in the TR version of this filter. Can you try the non-TR version of the Page Turn filter to see if that works for you?
Cheers,
Peter.
Brian Holson
on Mar 2, 2009 at 2:14:32 pm
That worked! Thanks for your help, it is greatly appreciated!!!!
Brian
