Red+FCP equivalent of "create composition clip" in m100??
COW Forums : Boris FX
Maxwell Federman
on Sep 29, 2008 at 11:39:42 pm
Hello
When using a workstation with FCP and Boris Red (for FCP) installed, what is the best way to go about creating a composition clip to import the boris project files into?
In Media100, it's really easy with the "create composition clip" command; and I hope FCP has a similar set-up. I'm just not sure what that is. If there is a Boris+FCP tutorial posted somewhere I would really appreciate a link...
Thanks for taking the time to read this post.
Max Federman
peter mcauley
Re: Red+FCP equivalent of "create composition clip" in m100??
on Sep 30, 2008 at 1:27:06 pm
Hi Max,
In FCP you can apply RED to any clip in the timeline without specifying that it is a composition or graphics clip / track. RED exists as a filter and transition in FCP so you simply drag a clip into the timeline, then drag the RED filter onto the clip, click on te RED banner in the controls window and you are into the RED user interface. Create the effect and click on apply and you are back in FCP.
I hope this helps,
Peter.
Maxwell Federman
on Oct 18, 2008 at 10:13:52 pm
Thanks Peter
There is a problem. When Red loads from FCP the dreaded green "proxy track" appears with a number two below it. I am using FCP 6.0 If I apply a filter to the green track the changes appear when I return to FCP. But I need live preview in RED.
Do you think there is a settings problem?
Also the footage was captured using the pull-down removal preset in FCP.
Source material is DV 24p shot with a NTSC-region JVC GY-HD100A
Thanks Peter
Max Federman
peter mcauley
on Oct 20, 2008 at 1:04:05 pm
Hi Max,
You can change this by doing the following:
• launch RED
• from the pulldown menus in RED select ... Preview>Image>Update Source
This should give you a live preview in RED within FCP.
Cheers,
Peter.
