BCC Keyframe issue
COW Forums : Boris FX
Thomas Bays
BCC Keyframe issue
on Sep 25, 2008 at 7:47:30 pm
I just got upgraded to Avid 3.0 and I'm having problems with keyframing the effects that come with it. Whether I'm in the effects editor or adding keyframes in the record side...each change I make makes every key frame change.
I'm very frustrated...I hope I'm just doing something really stupid. thanks.
peter mcauley
Re: BCC Keyframe issue
on Sep 29, 2008 at 1:21:58 pm
It sounds like the default keyframe interpolation is set to constant ... try setting the default interpolation for something other than constant, such as linear, and it should behave as expected.
Cheers,
Peter.
Ra-ey Saleh
on Nov 4, 2008 at 5:15:18 am
Having the exact same issue on Symphony DX v3 (reported it to Boris Support).
The 'Constant' interpolation is more a Boris Red/FX thing as these options don't exist in BCC
(I know this is the FX forum, but there you go...)
Hopefully this will be 'fixed' soon.
