which bcc?
COW Forums : Boris FX
sergio anaya
which bcc?
on Feb 19, 2008 at 10:49:21 pm
A friend of mine asked me which BCC to use as plug in with BR
he edits with Canopus Edious but uses BR to improve his works, in the BCC page is mention different hostes but it does not mention BCC for BR or Edius!!.
So, which BCC to use with BR?
Avid, AE, PP, FCP, AC??
I expect you can help me on this
Best regards
3.2 Gb processor
1 Gb DDR
peter mcauley
Re: which bcc?
on Feb 20, 2008 at 3:59:45 pm
BCC is currently available in 4 host API versions:
BCC AE - for hosts that use the After Effects API (AE, RED)
BCC AVX - for all Avid hosts
BCC FxPlug - for all Apple hosts (FCP, Motion)
BCC Sparks - for all Autodesk Systems hosts (Flame, Smoke etc)
If you are using BCC 5 from within Boris RED then you need to use the BCC AE installer, regardless of the host that you are plugging RED into.
I hope this helps.
© 2018 All Rights Reserved
