jagged edges on text in RED and media100
COW Forums : Boris FX
Felix Halter
on Feb 18, 2008 at 8:33:12 am
Since quite some time I'm getting these jagged edges:
and I can't get rid of them anymore.
The above text sample is vector based arial, size 216, in the styles palette choose bevels Nr. 1 America, and put this on a black background.
The jagged edges appear in RED 4.1 with Producer and with HDx (lossless codec). They don't appear in 8.2.2 and RED 3, so If I hook up the monitor to the old 8.2.2 and RED 3 everything looks fine.
Now here is an interesting one:
If I toggle the resolution in RED between full, half and quarter I see the changes on my monitor. But if I toggle quality between high and draft I don't see any change at all, same as if I press "display HQ frame to monitor", no change. So it looks like my system is outputing draft quality only!! Where can I change that?
(btw. play real time effects and titles in draft quality is not checked in the project settings of m 100) And one more thing: Direct export from RED to QT looks fine.
Any help would be greatly appreciated.
Thanks, Felix
Scott_F Media 100
Re: jagged edges on text in RED and media100
on Feb 19, 2008 at 4:22:17 pm
Hi Felix,
Are you seeing the Jaggy text in the Boris Red Composite window on inside of Media 100 Producer? What version of Producer are you running? If you want to you can contact me at
Scott F
Media 100/Boris Fx
© 2018 All Rights Reserved
