Problem with .swf export
COW Forums : Boris FX
Mike Allen
on Feb 7, 2008 at 9:45:05 pm
When I export a file as a .swf I can see a progress bar showing the frame by frame export. When I go to the folder that the file is sent to, there is no .swf file to be found. Can someone help me with this please. Also, is XDcam HD support comming soon?
Mike
peter mcauley
Re: Problem with .swf export
on Feb 8, 2008 at 3:22:21 pm
We are able to reproduce the issue and will institute a fix for this with a forthcoming point release.
Meanwhile, you can find the exported flash file at the root level of the hard drive - the problem is with the destination and RED seems to be ignoring the user specified destination for the export and saves it to the root level of the HD instead.
Regarding support for XDcam HD ... we'll look into it and see if this is something that we can do with a point release.
Cheers,
Peter.
Mike Allen
on Feb 8, 2008 at 4:34:00 pm
Thanks for the prompt reply. It is great to know I can get help here.
Mike
