BCC3 and avid alpha
COW Forums : Boris FX
bryan parris
BCC3 and avid alpha
on Jan 17, 2008 at 3:42:07 pm
I confess I haven't used these filters much over the years that they've been on the avid. I'm trying to add a transparency mode (like linear burn) to a graphic that already has an alpha (created in the title tool). I first looked at the Composite filter which has modes like this in it, but I can't seem to get it to work with the alpha properly. For that matter, I can't get any BCC filter to apply to the title properly. A pdf from Boris says it's a one step process -
"Any effect in the BCC AVX package can safely be added to a native Avid title and the alpha information is preserved along with the title making it a one step task to apply a directional blur or light zoom effect to the text."
However, when I drag directional blur to the title, all I see is the b&w alpha on the screen. If I hold alt and drag, it applies the effect to the video as if there's no alpha.
I'm using BCC version 3 with Avid MC Adrenaline 2.8. Is the BCC too old?
Bryan
peter mcauley
Re: BCC3 and avid alpha
on Jan 17, 2008 at 4:59:32 pm
You need to enable the Apply to Title Matte function in the BCC filter in order for this to work.
I hope this helps.
Peter.
bryan parris
on Jan 17, 2008 at 5:13:09 pm
Thanks Peter.
Simple enough - so it's a two step process :0)
That does the trick.
