how to change angle of rain
COW Forums : Boris FX
jack halsey
on Dec 22, 2007 at 9:43:34 pm
Hello
I have a scene where someone is looking over the edge of a building and I would like the rain to come straight down from that POV..I am unable to change the paramaters in the rain in BC to affect this. Any ideas would be welcome and thank you.
Peter McAuley
Re: how to change angle of rain
on Dec 27, 2007 at 4:13:22 am
You might want to apply the rain filter to a new solid layer, apply the BCC Rain filter, enable the "Composite on Alpha" switch in the filter controls, then using host controls set the layer to 3D (assuming of course that you are using either Boris RED or Adobe After Effects,) then you can tilt the layer (using the host x rotation parameter) back to match the POV of the camera.
I hope this helps,
Peter.
