keyframes
COW Forums : Boris FX
mark crawford
keyframes
on Dec 7, 2007 at 7:59:04 pm
I'm having trouble with keyframes. I've inserted a lower third template along with two text boxes and another text box placed in the upper right corner.
I need to move the text and border around. I set the location of where I want the border and text and set a key frame at the beginning of the clip. I then copy the keyframe and place it at the end of the clip (thinking that will keep the text and border from moving around). IT DOESNT. It starts out where I want it and ends where I want it, but in between the text and border move around slightly.
WHAT CAN I DO TO SET MY TEXT AND BORDER WHERE I WANT IT AND KEEP IT STATIC AND IN PLACE THE ENTIRE CLIP???!!!
Alan McCormick
Re: keyframes
on Dec 7, 2007 at 8:21:40 pm
Mark, set your keyframe interpolation to hold for those specific keyframes. If need be add the tracks you want to move in a container or the opposite add the static tracks in a container and keyframe the container. It all depends exactly what you want to do.
Regards
Alan
