Transparent Key in BCC 5.0.1
COW Forums : Boris FX
Matthew Lopes
on Nov 16, 2007 at 2:39:54 pm
I'm having the same problem. Perfect key until rendered out then its kind of transparent. Need help!
Intel Mac, FCP 6.0.1, BCC 5.0.1
JeremyG
Re: Transparent Key in BCC 5.0.1
on Nov 16, 2007 at 6:39:22 pm
I would email BorisFX right away.
Vik Narayan
on Nov 16, 2007 at 8:50:21 pm
Matthew,
Can you give a little more details about your situation. Are you using just a chroma key, or are you using any additional matte contol plugins? Have you checked the key against the checkerboard background? - this is a good way to see if there is transparency in the 'opaque' areas of the frame.
JeremyG
on Nov 16, 2007 at 9:05:48 pm
Oh no, this is not a bad kay, this is a bug. After rendering, it appears as if a transfer mode is applied to the key subject.
http://forums.creativecow.net/thread/15/857204
Jeremy
Matthew Lopes
on Nov 20, 2007 at 3:42:34 pm
I went back to using BCC 4 and it worked perfectly but render time was much slower. I hope this gets addressed quickly.
JeremyG
on Nov 20, 2007 at 4:19:12 pm
Me too. Stopped me short in a project.
