Red and Media100 Version 12.
COW Forums : Boris FX
greggm
on Oct 10, 2007 at 3:17:14 pm
Is there a Red installer that works with Media100 Version 12? I have the last 4.1.5 installer, but it only refers to M100 11.6.
Thanks.
peter mcauley
Re: Red and Media100 Version 12.
on Oct 10, 2007 at 5:21:04 pm
Well I guess we need to start by asking you what level of Media 100 system you have. If you have M100 HS Suite or M100 HDX both or which come with RED, then it is installed during the M100 host installation process. If you have either the M100 SDE or HDE then you would need to purchase RED and run the RED 4.1.5 installer, select the custom host option and manually navigate to the V12 plug-ins folder. We will release the RED 4.1.6 installer to the web site very soon, once we have completed the test process for this updater.
I hope this helps.
Peter.
greggm
on Oct 10, 2007 at 5:50:17 pm
I have an HDe and a purchased version of Red 4.1.5
peter mcauley
on Oct 10, 2007 at 5:58:07 pm
Okay ... so then the custom host install option should work for you. If you need any assistance with this please let me know and I'll provide detailed instructions.
Cheers,
Peter.
