larger font
COW Forums : Boris FX
Axel Andy
larger font
on Jul 24, 2007 at 5:18:25 pm
Due to too much eye strain I tried enlarging the font from my windows display settings. The problem is that it cuts off some of the menues and function buttons in Boris. I've got a screen shot if you want to see what I mean. Is there a way for me to have larger fonts and still use Boris without losing the necessary buttons?
peter mcauley
Re: larger font
on Jul 25, 2007 at 6:12:25 pm
Unfortunately there is not much that we can do to help - there is only so much space available for text in the UI and if the font size is increased then there is less space available for characters describing the parameter and they become truncated.
One thing you might want to try is instead of changing the font size, you can change the resolution of the display, say going from 1280 to 1024 and see if this helps. This way I don't think the text description would become truncated. You may want to use at minimum a 21 inch wide monitor if you do this.
© 2018 All Rights Reserved
