Adjusting Gradients in BCC for AE
COW Forums : Boris FX
Kevin
on Jul 23, 2007 at 7:34:36 pm
How do I create my own gradients in BCC?
I can load and save but how do I adjust existing gradients or make new ones?
peter mcauley
Re: Adjusting Gradients in BCC for AE
on Jul 24, 2007 at 2:50:41 pm
If you are referring to the gradient section of one of the Rays or the Colorize Glow filters then all you need to do is to twirl down the Colorize Group, set up the gradient that you want to make, then press the S button in the Color Preset banner so save the preset. To load one, you use either the pop-up list or you can press the L button in the Color Preset banner.
All of the factory presets are user modifiable and you can create and save an unlimited number of gradient presets - and all of the filters that feature the Gradient section access the same Gradient preset list so you can create a gradient in one filter and use it in another filter.
I hope this answers your question.
Cheers,
Peter.
