PICT Files Won't Import
COW Forums : Boris FX
Aurien
on May 5, 2007 at 2:42:37 pm
As a new Boris user I am stumbling over a few things. The first tutorial involves importing some PICT files from the supplied folder. When I try to import them (click on V1, navigate to the files) only the single PSD in the folder is available, all the PICTS are greyed-out.
I tried resetting Preferences to Factory Settings, but that hasn't helped.
Lee Berger
Re: PICT Files Won't Import
on May 6, 2007 at 4:30:47 pm
Try dragging them from the finder to the track (left side of the interface where you select the type of track).
Aurien
on May 6, 2007 at 8:10:24 pm
Well, I'll be darned. It worked. Not that the interface shouldn't import PICTS, but it is a perfectly effective workaround. Thanks
Carl
Lee Berger
on May 6, 2007 at 9:34:23 pm
I'm glad it worked out.
