BCC Lens Flare for RED 4 running on Media Composer Adrenaline
COW Forums : Boris FX
Editz541
on Feb 15, 2007 at 6:34:42 pm
Are we going to see this particular filter show up in future updates? Good to see the various BCC Rays filters in RED 4, but Lens Flare is the one I use most.
Peter McAuley
Re: BCC Lens Flare for RED 4 running on Media Composer Adrenaline
on Feb 16, 2007 at 2:01:51 pm
We discovered an issue when using any of the OGL filters (Lens Flare is one of these) in RED while running inside of the Avid host and were forced to make the decision of removing the OGL filters from RED until we have a fix for the problem. It is unclear at this time when the resolution for this issue may come about - hopefully by the next release. Meanwhile you can still use the BCC AVX OGL filters (including the lens Flare) to achieve that result.
We apologize for any inconvenience this may cause.
Cheers,
Peter.
