ICE'd FE Power Pin Problem
COW Forums : Boris FX
Ajmetz
on Dec 13, 2006 at 11:54:48 pm
Hi, Am using the FE Power Pin filter within Boris FX 6.01, and once I've adjusted the corners to where I want the video, I'm getting echos of the original video appearing elsewhere.
To be precise if I move the top left corner in beyond the bottom left corner, a repeat of the video suddenly appears on the left of the screen, if I make a similar adjustments to the bottom corners, a second repeat video appears at the bottom.
Oddly enough, this doesn't happen if the "unstretch" checkbox is selected. However, the "unstretch" checkbox, and I quote from the FEC guide: "inverts the function of the pins" meaning, I have to drag the corner pins in the opposite direction I want them in order to achieve the effect, which is very, very confusing.
Surely there must be something I can do to just get this corner pin effect to behave?
Failing this, I will have to resort to a simpler scale and slant approach.
