Adding FX as a filter in FCP
COW Forums : Boris FX
matt short
on Jun 23, 2006 at 5:51:52 pm
When I apply FX to a clip in Final Cut and launch the Boris interface, there is nothing in the timeline. Shouldn't the clip I applied it to appear? I looked in preferences and the open empty timeline box was unchecked.
peter mcauley
Re: Adding FX as a filter in FCP
on Jul 6, 2006 at 9:08:41 pm
hello,
you may have to add the clip to the image well for the filter within the fcp interface - i've seen this before in fcp. or you might just want to add a new track in the FX interface (command + K) to see if that does the trick.
i hope this helps
peter.
