NO VCR buttons BR!!!
COW Forums : Boris FX
sergio
on May 29, 2006 at 4:49:24 pm
I have this problem, When I install BR 3.0 is ok but when I install the update to 3.0.4 I have not VCR buttons in the composite window!!! Why is this? Anyone with the same problem? how to solve it?
I mostly use Red as alone engine even I edit with LE 6.1 and Red works as plugin on it.
mark harvey
Re: NO VCR buttons BR!!!
on Jun 2, 2006 at 12:58:27 pm
TRy deleting the preferences and then restarting the application. If you are on windows, the preferences is an .ini file Do a search on your c drive for *.ini and delete the one that comes up for Boris Red. If you are on a mac, then I am not sure where it is other than it should be where all preferences are stored.
Hope this helps
Mark
cowcowcow
Paul  FX
on Jun 2, 2006 at 7:26:52 pm
In Start > Control Panel > Display, go under the Settings tab and click on Advanced. See that the DPI for your computer is set to Normal (96 DPI)it should be in the General tab.
sergio
on Jun 12, 2006 at 4:11:40 pm
I alredy did it, but I had not sucess, any other advice??
You know, it is funny because this happen only when I up date and in any update I get a window message telling me " wait, serching for stuido.mod file" can this file be the problem I have?
Regards
