Boris FX and Liquid 7
COW Forums : Boris FX
simonltv
on Apr 3, 2006 at 6:30:04 pm
Please anbody help
I have purchased boris fx and instaled
it works from the desktop but not showing up
in the effects file in liquid 7 I understand a few people have had
issues with this.. question anybody any ideas of how to fix it
is it a Boris issue or a liquid issue ?
thanks in frustration !!!
mark harvey
Re: Boris FX and Liquid 7
on Apr 4, 2006 at 1:40:24 am
Make sure that you install Borisfx after you have installed Liquid.
Now, in the library within Liquid, it should be under the added clip effects section. Also it should be listed under the added transitions section in the library.
Regards
Mark
simonltv
on Apr 4, 2006 at 8:42:42 am
thanks mark
have reinstalled liquid again
then installed FX.... when I load Liquid it reaches
69% and hangs ..any ideas !?
simon
Mark Harvey
on Apr 4, 2006 at 8:54:00 am
Make sure that you leave Liquid alone, even though it is hanging. It is most likely searching for plugs...this can take up to 2 minutes. If that doesn't work, post in the Avid Liquid forum and we'll continue there.
Mark
simonltv
on Apr 4, 2006 at 9:57:52 am
mark have posted on the avid liquid pro
forum..left liquid half hr still hanging !!
simon
mark harvey
on Apr 4, 2006 at 12:52:06 pm
Ok...I meant that you could also post on the Avid Liquid froum here at the COW....
Regards
Mark
