need help using Boris Red 3GL in a 23.976 AVID Xpress Pro project
COW Forums : Boris FX
dustin
on Apr 2, 2006 at 9:59:35 am
I have never used Boris Red in a 23.976 project, but I need to now, and I'm noticing that any clips with a Boris Red effect applied are turned into an interlaced clip, and then only 1 field is being played, So not only are the clips with a Boris effect applied interlaced, but they look like crap. Is there any kind of setting in Boris for it to be able to take incoming Avid data as progressive, and spit it back out progressive. I have tried messing with many of the Preferences. I have set the Import Movie and Export movie settings to be Non-interlaced. Has anyone else had this issue?
I am using Avid Xpress Pro HD 5.2.1 and Boris Red 3GL 3.04
mark harvey
Re: need help using Boris Red 3GL in a 23.976 AVID Xpress Pro project
on Apr 4, 2006 at 1:42:12 am
At a guess :-)
Make sure that in the prefs, use host settings is checked, then in the render tab, make sure that render better field rendering is unchecked.
hope this helps
Mark Harvey
