Red Trasition Question
COW Forums : Boris FX
Mike Allen
on Mar 14, 2006 at 10:09:04 pm
Thanks for all the help in getting Red 3.0.4 installed. It seems to be working fine. I do have one more question. My last system was a Media 100 system. With M100 I could drop a Boris transition in the timeline, just like a crossfade and it rendered perfectly (no timing issues and did not have to deal with wells). Now with FCP5 I can drop the trasition wherever I want but when I go into boris there are now numbers where the video should be. So, with very little effort, I learned to drop the video into the video tracks on the control tab before entering the boris application. Then when I go into boris I now have video instead of the numbers representing tracks. The problem is timing. The trasition is now out of sync with the flow of the video. Is there a quick way to apply the boris transition and have the flow of the video transition properly as if I had just applied a crossfade. I am sure this is a very simple question. In M100 it was a drag and drop. What is the shortcut in FCP5?
