Problems with jittering image
COW Forums : Boris FX
Henrik Helms
on Jan 5, 2006 at 5:48:26 pm
Hi!
I uses Boris Red inside FCP5 - and when I have a uncompressed sequence and makes an image or logo move in a Boris effect it jitters when it moves. When I do the same effect in a DV-PAL sequence it works fine - but not in uncompressed.
What am I missing??
Greetings
Henrik Helms
dBA MEDIA
Mark Frazier
Re: Problems with jittering image
on Jan 19, 2006 at 11:19:38 pm
I've had similar issues, primarily with moving text. In your preferences, under the Local Projects tab, check the box for 1:2:1 Deflickering and see if that helps. Unfortunately, this will not remain the default setting (even though the box says that it will), so you will have to do this with each new project.
Hope this helps, and hope it's not too late.
Mark
