COW Forums : Boris FX
Fame Little
on Dec 15, 2005 at 10:15:44 pm
Hi All, I'm using Boris Red as a plugin with FCP and what I did was turn one of the clips in the timeline to a cube shape but how do I assign other clips in the timeline to face 2 and so on. I shot the footage in 16:9 if I select clip direct from the hard drive it don't come in as 16:9
Anne Renehan
on Dec 20, 2005 at 3:46:06 pm
To map different media to each face of the cube, you need to click the Multi/Single-input icon on the cube track so that it is in Multi Input mode. This icon appears as an "M" when it is in Multi-input mode and an "S" when it is in Single-input mode. In Multi-Input mode, you can choose the media that you want for each face by pressing hte Meida icon and choosing from the menu that appears. You will need to drag the FCP tracks into the Input wells in the Filter tab.
I'm not sure about the 16X9 issue. There is a 16X9 menu option in General tab of the preferences window.
© 2018 All Rights Reserved
