Red 3GL
COW Forums : Boris FX
Tim Langston
Red 3GL
on Sep 30, 2005 at 11:14:45 pm
Any sign of a fix for field rendering when using Red as a generator in FCP?
Tim
Tim Langston
Cryin' Out Loud Productions
Fort Wayne, IN
http://www.colproductions.com
advres
Re: Red 3GL
on Oct 3, 2005 at 12:16:42 pm
Red will field render any asset added to the wells in fcp or imported into red via the boris UI when using it as a generator in FCP. That was recently fixed. What was not fixed was field rendering of assets created in Red (i.e. text, splines, etc). The easy work around would be to add a slug to your timeline, apply red as a filter to that slug and you should have accurate field rendering and be able to make the comp any size you wish. This is of course just a band-aid solution that needs to get fixed. Unfortunately, I have not heard any news on when that fix will be implemented but at least you can get your work done, however inconvenient it may be.
Tim Langston
Re: Red 3GL
on Oct 4, 2005 at 1:59:52 am
Yep, that's what I've been doing...just adds an extra step. We paid more than FCP itself, just wish it would work.
Tim
Tim Langston
Re: Red 3GL
on Oct 8, 2005 at 6:36:00 pm
Looks like 3.0.4 renders in fields. This is GREAT!!
Thanks Boris,
Tim Langston
Tim Langston
Fort Wayne, IN
