Probs with Red 3.02 as plug-in for Prem Pro 1.5
COW Forums : Boris FX
Tim K
on Sep 28, 2005 at 7:58:05 pm
Recently Installed Red 3.02 as plug in for Prem Pro 1.5, on system running Matrox RTX100.
When I re-open a project with Boris Red comps & effects previously applied to clips, effects manager in Prem Pro says 'filter not recognised' and the clip plays sans fx / filters. Also frequent crashes when rendering applied filters (notice a lot of probs particularly with blurs). Premiere also loses track of correct Preview files associated with Boris FX'd clips..
Anyone using Boris Red as a plug-in for Prem experienced this sort of hoodoo? I've re-installed both apps several times to no avail.
Any tips appreciated, system info on my profile.
Tim K
Re: Probs with Red 3.02 as plug-in for Prem Pro 1.5
on Oct 1, 2005 at 2:49:39 pm
For anyone interested - problem now sorted - had to go into Adobe plug-ins folder on system drive and manually remove a couple of rogue instances of an IMborisred.prm file and FL6borisred.prm file in the filters folder which kept appearing on every install.
