Continuum only works once!!!
COW Forums : Boris FX
REDEXIT
on Jul 15, 2005 at 11:23:28 am
This is driving me nuts!! After installing BorisFX Continuum (3.0.4)
it will allow me to use the filters/generators for only one session
in FCP 4.5. If I quit FCP, next time I open up I get an error
message saying I need to re-install. Please can anyone shed light
on this problem.
Regards
Neil
G5 DP2ghz 10.3.9 QT7
advres
Re: Continuum only works once!!!
on Jul 16, 2005 at 3:06:45 pm
You should contact their customer support line. It is a known issue and they can get you taken care of even though I didn't see their hotfix on the website.
Until you get a hold of a fix, all you have to do is delete your FCP POA cache before launching FCP. It is located in Home folder > Library > Preferences > Final Cut Pro User Data > Final Cut Pro POA Cache. UNfortunately, you will have to do this everytime you launch FCP until you get the fix... but at least you can get your work done.
REDEXIT
on Jul 17, 2005 at 8:36:58 pm
Thanks advres , this was also a problem in ver 3.0.1
My reseller in the UK supplied me with a replacement
version 3.0.4 and it's still buggy.
Sorry BorisFX, big thumbs down to you!!
