Adobe Encore crashes upon menu creation
COW Forums : Adobe Encore DVD
Guillermo Gomez
on Mar 29, 2018 at 6:51:12 pm
I have a problem: whenever I import a PSD menu into Encore CS5.1 for a Blu-Ray project, Encore just quits on me. The PSD file appears in the project’s Sources > Menus folder, but Encore crashes even if I hit Command-M (New Menu). I’ve tried deleting the preferences file from the library, but it still didn’t work.
Mac OS 10.13.3 (17D47)
iMac (21.5-inch, Late 2012)
3.1 GHz Intel Core i7
16 GB 1600 MHz DDR3
Stan Jones
Re: Adobe Encore crashes upon menu creation
on Mar 29, 2018 at 9:45:33 pm
There were some issues with Macs and psd functions.
Once imported, is the menu in the menu viewer?
Can you import a menu from the library?
You say you reset the library preferences; do you mean the Encore preferences?
Was 5.1 working okay previously?
Stan Jones
Guillermo Gomez
on Mar 29, 2018 at 10:07:35 pm
No. There are no menus in the viewer.
I don't think so. Which library?
I mean the .plist file.
Yes, the last time I used it, a few months ago, I think before the upgrade to High Sierra.
Stan Jones
on Mar 30, 2018 at 12:40:09 am
The most frequent problem for new Mac OS is permissions. Make sure all Encore folders and files are read/write.
This link is for Premiere, but may have some relevant info.
http://blogs.adobe.com/kevinmonahan/2014/09/10/premiere-pro-cc-freezing-on-...
Not sure about Mac reset; see this link:
http://helpx.adobe.com/x-productkb/global/troubleshoot-system-errors-freeze...
Your issue reminds me of the "Photoshop -1" error that Mavericks users were getting (when it was new). The workaround was not to left click and to use right click or menu commands. Perhaps the parallel for you would be not using keyboard shortcuts?
In any event, permissions have the best chance of fixing the problem.
Stan Jones
Guillermo Gomez
on Mar 31, 2018 at 10:42:19 pm
It also crashes when I use any method other than keyboard shortcuts. I even tried opening a previously made project with a menu in it, and while that old menu worked, it crashed every time I tried to create another menu in the same project. It works when I import a PSD file as an asset, but not as a menu.
Stan Jones
on Apr 1, 2018 at 12:33:11 pm
Were your permissions set correctly? did you need to change any?
Stan Jones
Guillermo Gomez
on Mar 29, 2018 at 10:08:36 pm
The debug database looks like this:
AEResolveQTDataRefs true
AME.EnablePresetDB false
AME.EncoderHost.NoXMP false
AME.amewrapper.donothide false
AlwaysEnableDynamicLink false
CloseAlwaysTimeoutInSeconds 300
CloseIfContentionTimeoutInSeconds 15
CompareMediaNodeRenderers false
CreateLogFilesThatDoNotExist false
DVDHighlightInterpolation 3
DisableCUDADisplay false
DisableMultiCamAcceleration false
DisableNewMediaNodeRenderer false
DisableSpeculativePrefetching false
DumpPresetFilePassedToAME false
DumpProject false
DumpQueueOnDroppedFrames false
Enable420Shaders true
Enable422Shaders true
EnableCUDAStabilizerWarpNode false
EnableDogEars false
EncoreBuildsleepMsecs 10
ForceAIFRenderToCPUOnly false
IgnorePlayerStop false
LegacyQTCodecsAndGamma false
MPEGDisableMultipleOpens false
MinimumDelayBetweenFlushesInSeconds 1
NumberOfInstancesBeforeContention 5
PSmemUsagePercent 20
Player.EnablePerfomanceStatics false
PlayerAccelMode 3
QTUseSourceGammaLevel false
UseFrameBlendingForAME false
UseMediacoreForLivelink true
UseRemoteExporters false
ame.pipeline.dumpframes false
assert.enabled false
enableChangeAuthorContextFromBuildPanel false
Karen Nadalin
on Jun 27, 2018 at 9:15:44 am
Hi, Guillermo,
I'm having the same problem using Encore CS5 with Mac High Sierra OS 10.13.4. This is driving me bonkers. Every time I try to add a new menu, whether with File > New > Menu, command-M, double-clicking one from the library, etc., it crashes the program. I've also tried trashing the preferences and even restarting the machine.
Did you ever find a solution?
Karen
