Encore DVD keeps failing
COW Forums : Adobe Encore DVD
John Perez
on Mar 17, 2017 at 12:38:15 pm
I'm unable to burn a DVD. I have tried both my burners. Any idea what it might be?
HP Intel(R) Core i-7 CPU
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
As always thanks so much to you guys...Johnny In Orlando
John Perez
Re: Encore DVD keeps failing
on Mar 17, 2017 at 12:46:37 pm
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
John Perez
on Mar 17, 2017 at 12:55:46 pm
Won't let me burn an image either
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
John Perez
on Mar 17, 2017 at 1:09:41 pm
I get "Access Denied" when I try to burn an image. And now I get "General error" when I try to preview
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
Jeff Pulera
on Mar 17, 2017 at 2:03:00 pm
Hi Johnny,
Looks like you have 3 different kinds of video clips in the project -
  • .mpg
  • .m2v
  • .mp4
My guess is that the .mpg or .mp4 clips - or both - may be at fault.
ANY video clips you want to use in Encore should be .m2v, created from Premiere/Media Encoder using the MPEG-2 DVD format. Then you are not asking Encore to do a bunch of transcoding of the material, since in the end it all must be MPEG-2 before it goes to disc. Better off to just provide Encore with DVD-ready material to start with.
I also can't tell from looking at the screen grab what the frame sizes and frame rates are of all the different clips. Could some be HD, or have different frame rates? Should all be 29.97 in the US.
Jeff Pulera
Safe Harbor Computers
John Perez
on Mar 18, 2017 at 11:53:22 pm
Thanks so very much for taking the time to explain these to me. I will report back to you on the results.
950 @3.07G 3.07
RAM: 8 Gigs
64 Bit Op System
