Images in Slideshow are horizontal instead of Vertical
COW Forums : Adobe Encore DVD
John Perez
on Feb 5, 2017 at 6:49:27 pm
Several pix in my slideshow are incorrectly rotated. 'Should be vertical instead of horizontal. The are properly rotated in Photoshop. Why is this, and how can I fix? Thanks!
As always thanks so much to you guys...Johnny In Orlando
John Perez
Re: Images in Slideshow are horizontal instead of Vertical
on Feb 8, 2017 at 4:32:56 am
Can i get a witness?
Jeff Pulera
on Feb 8, 2017 at 8:59:50 pm
Hi Johnny,
So are you trying to make a slideshow directly in Encore, importing stills? Never tried that, always do my work in Premiere then export MPEG-2 DVD for use in Encore.
First suggestion would be - make all the stills a uniform 720x480 for DVD. If you have odd sizes, maybe that is causing issues, like if image is taller than it is wide? Or just make the slideshow in Premiere to start with, a lot more flexibility with adding effects and music and such.
Jeff Pulera
Safe Harbor Computers
John Perez
on Feb 10, 2017 at 11:46:58 am
Thanks so much, Jeff. Yes, was trying to use the Slideshow feature in Encore. I will do in Premiere...
