DVD Zoomed-in issue. Overscan?
COW Forums : Adobe Encore DVD
Marc Walker
on Dec 13, 2016 at 5:49:22 pm
Hi all,
I have spent some time attempting to create high quality DVDs from HD FLV files using AME and Encore. But although I have followed every help guide, read the support literature and used logical sense, approx 10 pixels are missing vertically and approx 20 horizontally when I play it on a DVD player(I have tried 2 players/TVs with same result)(like a slightly zoomed-in effect).
In Encore and WMP, it plays perfectly fine.
This is the transcoded file:
General
Complete name : J:\Authouring DVDs\Disc 1\ZZ Top.m2v
Format : MPEG Video
Format version : Version 2
File size : 2.02 GiB
Duration : 57 min 12 s
Overall bit rate mode : Variable
Overall bit rate : 5 053 kb/s
Video
Format : MPEG Video
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=12
Bit rate mode : Variable
Bit rate : 5 053 kb/s
Maximum bit rate : 7 000 kb/s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.487
Time code of first frame : 00:00:00:00
GOP, Open/Closed : Closed
Stream size : 2.02 GiB (100%)
This is a VOB off the DVD(video info);
General
Complete name : G:\VIDEO_TS\VTS_02_1.VOB
Format : MPEG-PS
File size : 1 024 MiB
Duration : 26 min 51 s
Overall bit rate : 5 329 kb/s
Video
Format : MPEG Video
Bit rate : 5 031 kb/s
Width : 720 pixels
Height : 576 pixels
Standard : PAL
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.485
Time code source : Group of pictures header
Stream size : 967 MiB (94%)
More info:
The first DVD player(Panasonic) is quite versitile with regards to settings. I use the component(R/G/B) output(576p) and the HDTV(Samsung) recognises it as 720 x 576p. I have tried different aspect ratio settings on both TVs and DVD players and the best/closest settings are:
DVD Players: 16:9 (1.0x zoom)
TVs: 16:9
NOTES:
- Curiously, I have two video-loop-buttons "(%)" in the Main Menu, and in those, the same slightly zoomed-in effect occurs on the video, even while previewing in Encore, but I think that is because I used a 1280x720 thumbnail of the original HD video. Just thought I'd mention that.
- I used "Scale to Fill" during rendering, because of black lines on the sides.
- This issue is very recognisable due to the logo in the top left of the screen being 1/3rd missing.
- I am in the UK(i.e. PAL). But I wonder if a NTSC render would resolve this? Is this the kind of effect using wrong TV standards would cause?
Thanks for any help,
Marc
