Can you create a menu button to toggle Close Captions on/off
COW Forums : Adobe Encore DVD
Mitch Silver
on Feb 11, 2016 at 8:02:57 pm
Is this possible in Encore? I know you can do it with a DVD remote, but I want this feature on the DVD menu itself.
Ricky Barrow
Re: Can you create a menu button to toggle Close Captions on/off
on Feb 11, 2016 at 8:28:33 pm
Closed Captions are a function of the display (TV set). If you duplicate the movie, and thereby duplicating the space required on the DVD, add that timeline without adding the caption file and have a separate button for each, then yes, the button will allow or not allow captions.
Subtitles can be turned on/off with a menu button without duplicating the space required on the DVD but you need to duplicate the timeline (like adding a Playlist) and in that timeline, simply remove the subtitles track. Then your menu buttons can be mapped accordingly and subtitles will be forced on or off without using the remote.
Ricky
Mitch Silver
on Feb 16, 2016 at 6:51:59 pm
Thank you. Makes perfect sense.
