Can't change settings on NTSC field order
COW Forums : Adobe Encore DVD
clyde villegas
on Jul 22, 2015 at 3:21:21 am
I'm trying to create an NTSC DVD with Encore. I noticed that the setting for field option is dimmed out and cannot be changed from the default lower-field first.
I imported a video which is upper-field first to the project. When the DVD was created and then played on an interlaced NTSC TV, it looks fine. I thought the video will be jerky because the source was upper-field first but the settings is on lower-field first. Why did this happen? Can Encore detect the source video's field order and automatically adjust to it? Thanks! God bless!
ut in omnibus glorificetur Deus
Daniel Ludwig
Re: Can't change settings on NTSC field order
on Jul 24, 2015 at 12:41:47 pm
clyde,
this is depending on if you have transcoded your video allready, or if you use an (uncompressed) MOV or AVI.
ALL video-assets needs to have the same flie-order as their MOV or AVI-files.
encore could not detect the field-order within MOV- oor AVI-files, you need to SET it in the individual encoding-setting of each file.
danny
clyde villegas
on Jul 24, 2015 at 10:54:38 pm
The video is already transcoded (in MPEG2-DVD UpperField First using Adobe Media Encoder) before I brought it into Encore.
The reason why made it it upper-field-first is because the original footage was also upper field first (1080i Upper Field First).
Is there a way I can set field order in Encore to upper field first for DVD?
Daniel Ludwig
on Jul 26, 2015 at 1:35:22 pm
clyde,
this is very simple.
if you´ve imported a MOV or AVI-file into your project, you need to look t your project-window on the top left corner (normally).
do a right-klick on the (untranscoded) video, choose the transcoding-settings from the contextual menu.
from the window choose edit qualtiy presets. then you´ll get the typical media-encoder-window, where you can create a preset (with upper or lower field first)....
save the preset and go bach to the previous window. then you can select this preset for your trascoding - DONE! :)
danny
clyde villegas
on Jul 27, 2015 at 2:33:34 am
Thanks Daniel! You're instructions are very accurate. Was able to go through the settings easily.
I'm just wondering, my videos are already transcoded to MPEG2-DVD (upper field first) before I brought them into Encore. You mentioned that i should only do this with an "untranscoded" video. In the Project Window, in the DVD Transcode Status, it actually says, "Don't transcode."
Should i skip this step because my video is already transcoded and just go directly to building/writing on disc?
Thanks a lot Daniel ☺
Daniel Ludwig
on Jul 27, 2015 at 8:25:22 am
Clyde,
as soon as your assets allready transcoded (and a valid elementary-stream for DVD) you don´t need to set any transcoding-settings (as it´s allready done).
there´s only one point when you SHOULD use MOV or AVI and encore to transcode a DVD- or BD-file - if you need chaptermarkers on a dedicated frame!
background: adobe media encoder couldn´t set a necessary i-frame on previous generated (and marked) chapter-marker from premiere, it will generate I-frames depending on the previous GOP-structur... mostly this will result in NO i-frame on that dedicated frame, so no chapter-marker is possible in that case.
please keep that in mind.
danny
clyde villegas
on Jul 30, 2015 at 1:10:44 am
Thanks Daniel. But what does "a valid elementary-stream for DVD" mean?
Daniel Ludwig
on Jul 30, 2015 at 12:23:39 pm
hey,
valid elementary-streams are: m2v, mpv, ac3, dts or wav/aif
