Blu-ray Object: Export file not found -- Solved
COW Forums : Adobe Encore DVD
Neil Sadwelkar
on Jun 17, 2015 at 1:16:57 pm
Burning a complex multi menu Blu-ray. 6 timelines and lots of chapters. Took a while to set up links etc.
Checked project for errors. None found.
Tried to build a disk and got the error
Blu-ray Object: “_____”, Export file not found.
Searched here on the Cow as well as Adobe forum. No good reply.
Replies like uninstall and re-install Encore. Import media and redo menus and chapters. Or rename media files and reconnect. Tried everything. No luck. Rebuild entire project not an option. Too complex (and boring) to redo.
I even did a uninstall and re-install of Encore. And got the same error. Even transferred the files and project to another computer and tried. No luck.
Finally, removed all the .ac3 tracks in all timelines. Reimported the ac3 files. Placed them in timelines. Did a build. And it worked.
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
Per Scaffidi
Re: Blu-ray Object: Export file not found -- Solved
on Mar 21, 2017 at 3:51:30 pm
I fixed the same issue in Encore 5.5 by simply deleting the offending file from encore and re-importing.
